blackmagicbeeza
hi peeps,
having done a search on what headlight bulbs my ibiza sport diesel takes, i hoping you peeps can confirm i have the right ones, as i have yet to take the headlight out yet, so i cant really compare.
can anyone confirm i have bought the right bulb, ie H3, 12v/55w, which is what is stated in the manual? thet bulb that i have bought, is as above, it has a "corded" part. if that makes sense.
i have encloseda pic of both headlights and the headlight bulbs that i bought.
as ever, thanks for any advice, views. much appreciated
http://i3.photobucket.com/albums/y66/cheefchan/Image110.jpg
http://i3.photobucket.com/albums/y66/cheefchan/Image106.jpg
i forgot to add, i believe its the main beam that has blown. ie, the ones that i use at night.
H3 main beam, H7 dipped. Looks like it's got a wire attached it so that'll be the H3.
Good luck with fitting. Make sure you put them in the right way up and not upside down. They only go in one way! Check when you take the old ones out.
Is this an upgrade or replacement for a blown one? BTW, you don't need to take the headlight out. Can do it 'in situ'.
hey yalla beeza, i forgot to add its the main beam thats gone. ie the ones you put of at night. only one has blown, but i bought two so i was planning to replace them both?
