They are very much plug and play mate, and my beam pattern was excactly the same after fitting the HID's, so I wouldn't know about adjusting them.
And Krishen that's the same seller I bought off, but not too sure what bulb fitment your ibiza is, mine were H7, but I think yours might be different.
Yeah, the wires you plug your bulb in to go into the ballast, the wires that come out go in to the xenon bulb!!!Thats it!!!
www.ultraleds.co.uk is the place for LED's.
I have these as sidelights: http://www.ultraleds.co.uk/ultimate-501t10194-watt-ultra-xenon-white-p-1677.html
They are more expensive than the others, but I went through 3 or four of the "normal" ones and they just kept flickering because they were so close to the headlights, they were getting fried. The ones I linked to are designed to withstand the heat and have not failed me yet, the others went in a matter of weeks.
The ones I have for the numberplate/interior light/boot, are no longer listed on the site, but these should do the trick http://www.ultraleds.co.uk/37mm-leds-festoon-output-cool-white-p-1496.html
Cheers for the links. A silly question but the prices they have listed, are they per bulb or for a set?
per bulb I'm afraid :(
Some might state for a pair, but like I said the expensive ones are much better and do last longer.
These are my sidelights:
They are a good match for the 6000K HID's
Cheers Travis. They look awsome as does you car fella.
Also can anyone confirm that for the mk2 the side lights are 501?
