Headlight condensation
liam-lpm
seat ibiza 1.2
Jun 13, 2011
63
Kilwinning Scotland
Hi just new to the seat scene. just got my first seat ibiza mk4 a week ago and realised after washing it that my headlights steamed up,
to solve this I had a wee look about and eventually took off the cover and drilled two small holes in it this has seemed to of stopped the condensation
just wondering has anyone else found this problem and is it common
thanks liam:D
liam-lpm
seat ibiza 1.2
Jun 13, 2011
63
Kilwinning Scotland
aww yea it only appeared when i washed them and i soon had a wee look about, i only drilled two small holes and seems to have solved the problems. cheers
btw how do i upload pics of my car for my display picture?
JR750
95
Getting my FR tomorrow and this will be one of the first things I do :D
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
You either have to keep the units watertight (very difficult) or allow air to freely circulate (very easy). I drilled holes in the top of the light units. Even easier is to leave the caps off the back of the units. You might get a little condensation in there but it soon goes once you drive a bit!
Lum89
Instead of drilling holes would it be worth tryin the the seal at the back first if possible?
chrisRibiza
1,194
51
Sorry to dig up an old post, but my car is suffering the same problems. Where abouts did you guys drill the holes?
Many thanks
Sent from my GT-N7000 using Tapatalk
The holes need to be drilled in the back of the plastic cover which goes over the back of the bulbs and wiring. (The part which you unclip and take out when changing the bulb)
I drilled some holes in the back of it and also on the part which would be on the bottom. That solved all my condensation issues. The holes don't need to be massive, just big enough to allow air to circulate.
Stiglet
1,009
Surrey
Did mine on the bottom of plastic so water doesn't drip in. Used 5 mm drill bit and did 4 holes spaced out. Still get a bit of conden now and then but not much.
Edward9th
276
Dorset
I used silica gel sachets, in little holders glued to the covers, so easy to take out for 'recharging'. I also fitted a loop of thick nylon cord to the unreachable cover clip on the nearside. so when I want to re-fix the clip, I just pull the cord. (I had trouble doing this before - perhaps my arthritic fingers didn't help)
Lavery
332
Leigh, Lancashire
I used two hair dryers; one blowing inside the lights and one heating the outside. Made sure all moisture was out, covers back on (not drilled) and no issues since.
