firstleonowner
34
2 month old lean with led and auto lights
Driving today in the rain and very dark I didn't think headlights came on...no indication. When I got home I have tried turning headlights on and don't seem to be able to, I turn the dial furthest to the right and nothing lights up on switch or dash and headlights don't come on.
Tried the auto main beam assist function and that doesn't seem to work either.
The main beam does work when with the stalk
What am I doing wrong or do I have an issue, found fuse box under bonnet but can't believe there isn't an index for the fuses anywhere
Can't find the fuse box inside the car
Now it's a bit darker I have tried lights again and they do come on but still can't see any notification anywhere to show they are on and still can't get the main beam assist function to work
If I remember rightly the light symbol next to the light switch should illuminate green when the lights are activated, it's not at eye level so just cross your fingers :)
Thanks, I assumed the headlight next to the switch should light up ,the bottom right symbol.
The symbol above that does light up which I assumed was side lights
If your dash is illuminated (not just speedo, but dash&buttons), then lights are on. Otherwise are off.
You can clearly see it even in sunny day on two LEDs which illuminates your gearstick space (located under the roof in the middle).
There is no indication on speedo about status of lights.
