Thanks mate.Yes sorry it’s bumper off to get too the bottom two fixings
Sorry bud here you go. I've marked where I see an issueBlimey! Thats a close up.
Have you got a pic from slightly further away?
Hey bud sorry I just saw this. I'll move the car later get a better picture. The other headlight looks a little better but perhaps the opposite issue where it sits too inwardsNeed pictures off the whole front and even take one with the bonnet open as the slam panel may not be lined up correctly for them to be that far out
Hi bud. Thanks for the help. So the passenger side looked a little off compared to the other side so I loosen them 2 bolts and pushed the panel towards the engine and the headlight did move with it but only maybe 1 or 2mm.
The two bolts I have ringed do they match the two on the other side ?
If not just losen them and give that corner a little push to match the other side
Id bite the bullet and just go for it. Bumper off (at least that side pulled forward) ans see whats going on.Hi bud. Thanks for the help. So the passenger side looked a little off compared to the other side so I loosen them 2 bolts and pushed the panel towards the engine and the headlight did move with it but only maybe 1 or 2mm.
Do you think I might be able to get a better fit if I took bumper off?
Ahh perfect I think a combination of moving the slam panel and headlight will get me close thank you.The lower tabs are the same hole size as the upper ones so there is at least a few mm of left/right movement with the m6 sized bolt. I dug a spare headlamp out and you can see how much play there is.
Worth a try with the bumper off.
