Okay so a bit hypocritical given previous posts but am going to try and replace the turbo myself - I am fairly competent not confident.
So I think I need to do the following ?
A. Jack up car and put on axle stands
1. remove hard boost pipe
2. remove t.i.p and associated plumbing
3. remove oil feed line - do I need drain the oil first ?
4. remove water cooler line - do I need drain the coolant down first ?
5. from under car remove oil drain line
6. from under car remove coolant line
7. undo downpipe from turbo
8. undo turbo to exhaust manifold
9. undo and remove exhaust manifold
10. remove turbo
I have all oem gaskets, new exhaust manifold studs/nuts, new exhaust manifold to turbo studs/nuts.
What am I missing ?
10. remove turbo
What am I missing ?
