Edward9th
276
Dorset
My glovebox lid has started to jam. It appears that the bottom lip is catching on a sort of 'catch looking' thing on the tray beneath. Looking at it via torch and mirror, I can't see how it could ever have worked without catching. Obviously, I could see more with the lid removed, but the instructions for this are off-putting, so if someone has an easier solution, it would be much appreciated. I'm considering removing a small section if the bottom lip, which won't show, but I'd rather have a better cure. Thanks for reading so far! Ted
Back again! If anybody was looking into my problem, you can stop now, thanks. The obstruction was the centre fixing, a grotty plastic 'spike-in-the-hole' fixing, which had dropped out. I didn't trust it, so made my own fixing method, using another proper screw. Can't think why they used this!
BTW - I did try to edit out my mistake in the heading, but it wouldn't let me.
