HELP... How do you remove the inlet manifold???
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Yeah, that's a good idea really
Last time I looked they were about 60p ea from GSF. not big money even from a stealer
Mark is the seal number 11 in this picture?...
if so the part number is 06B 133 555 D ("insert for injector") and its £1.23, obviously you need 4!
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
removed the charge pipe, inlet manifold and TB today.
I also took my strut brace off which is also being re-polished too.
all in it took 3 hours for the lot.
the inlet manifold was harder than I thought because I didn't expect the hoses which are connected underneath it to be there! and they are a pain in the arse to get the clips of, especially that middle bugger!
Im dropping it off at Pristine Polishing 2mo and picking it up friday lunch time :)
though I'm not looking forward to putting it back on! lol :blink:
danieltm
Bit of Jabba magic!
Aug 26, 2006
796
Norwich
Look forward to seeing the pics when all polished!! I will be doing my polishing myself so could take some time...
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
i wouldn't do it myself, because of the time it takes to do it by hand, and yes ok you CAN get the same finish by hand, but VERY LITTLE ppl do!
plus, its only costing me £20 to do the inlet manifold and £25 to do the charge pipe!
I looked on ebay at polishing kits for drills and a decent one was £20 +
so tbh, I would much rather pay that little bit extra for a pro to do it and to save my body the hardship! :blink:
its worth paying for saving the hardship alone never mind the better quality finish! :yes:
danieltm
Bit of Jabba magic!
Aug 26, 2006
796
Norwich
I know what your saying but i have all the kit at my work and i also have 2 manifolds!! one on the car and one to work on, so im in no hurry to get it looking good ;)
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
Sorry to total hijak, is that thick part on the carge pipe a silencer, i remember someone talking about that, does anyone know if it causes any restiction or if it make a decent noise if removed?
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
BCM.. if you remove it it makes your turbo sounds a bit louder apparently and you MAY gain literally a couple of bhp
Iv looked at it and to be honest it is not for the faint harted!
I asked "Feel" on here how exactly you remove it and he said you need to heat it up, bash it, cut it, pull it etc etc and then weld in a sleeve!
so I cannot be bothered to do this, so wont! lol
see Feel's original thread... http://www.seatcupra.net/forums/showthread.php?t=44810&highlight=charge+pipe+silencer
edit: heres a pic of the silencer for you...
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Be intrested to see afgter pics fella as i need mine done again and the spare one.
Was £20 a "to you price" ow is that his price?
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
got the parts back today and WOW! :yes:
I had the following parts polished:
1. Inlet Manifold (i told him not to bother with its belly or at the bottom where it bolts to the engine as you cant see here with the engine cover on!)
2. Charge Pipe
3. Throttle Body
4. Strut Brace
In the end I paid £80 all in. I was originally quoted £60 all in but the guy wanted an extra £20 (he charges £20 an hour) as the charge pipe took him a lot longer to do. apparently he was too scared to put it in his acid bath to strip the grey/silver powder coat stuff off (as he didn't know if there was any rubber seals inside the silencer part!) so he had to grind it all off.
tbh I'm very happy with it all and I think £80 is a fair price, very quick turn around time too! (less than a day!)
enough talk and here are the pics, which I must say do NOT do them any justice at all! ;) ...
Not looking forward to refitting it all, but I will when I get some time!
over and out! :)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
yea i made sure i got the charge pipe brackets done as it looks stupid if they are not polished too! lol
