Help I have No Accellerator!!!
leon7284
Chelsea Chelsea
Jun 13, 2006
365
Horsham, West Sussex
all fuses are fine, earths are fine, checked the ecu connection while i was there none of the little pins were greeny, managed to unplug the pedal but couldnt get it off that all seems ok. So now it must be either the throttle sensor or the protensiometers? I managed to get the throttle adaption done but then when i started the car all went pete tong again so me thinks the throttle body is ok???
leon7284
Chelsea Chelsea
Jun 13, 2006
365
Had my car checked out today, my ecu is knackered!?! Its not supplying 12volts to the accelerator or the 5volts for the protentiometers so now ive got to send it off? Can anyone recommend someone?
leon7284
Chelsea Chelsea
Jun 13, 2006
365
Ok now i have a problem, i sent my ecu away for testing and repair but they say its fine!?! :shrug:
What do i do now? Am i going to have to take it to my stealership? There must be another option???
Someone must be out they that can help me :cry:
leon7284
Chelsea Chelsea
Jun 13, 2006
365
Got my ECU back now and shes all well again now! After they said it was fine i didnt believe them so they said that they will get some more pin data on my ecu and guess what they then found three burnt out connections to do with the accelerator pedal sensor and the maf! Dont know why it happened but all seems ok for now.....
