Help/info on dismantling interior
andycalvia
351
58
40
Ayrshire
:help: right, im looking at removing the centre consol (the bit round the radio, cup holder, climate control etc...) any idea on how to do this? ive tried and i can only get it off a tiny bit at the bottom and dont want to pull any harder incase it snaps :confused:
Also how do you remove the top of the gearstick, ive also been looking into this and cant seem to find anyway of it coming off :cry:
Then last but not least how do you remove the surround of the speedo dials?
Any help greatly appreciated and dont go off track as i think someone could make this a good sticky!
skoov
103
Derbyshire
www.hpieurope.com
andy3127 said:
ahhh ok thanx for that, where do u think i could get the key 2 remove the head unit from?
I got some audi keys from Halfrauds for a couple of quid. They aren't exactly the same as the SEAT ones (which I didn't know at the time, but once I got the unit out I bent them to be a better fit for next time) but they did the job!
I spent ages trying to get the head unit out with cut up credit cards to start with… to no avail!
EdButler
713
Sheffield
Take out the head unit - Get some keys generic for VAG cars from Hellfrauds - £2 ish
Take out the under tray (pull hard, first time its hardest)
Remove 2 Torx T-20's on the inner left/right of the panel.
Remove 2 Torx T-20's on the inner top section of the panel.
**if its your 1.2 thats it... If youve got CC instead of AC**
There are 2 Torx T-20's underneath the climate control box which screw threads go upwards. Therefore you need a slim or small screwdriver to get at them (i removed my ash tray bits and my screwdriver 'just' fit in there to coax em out.)
Then just pull it, theres a few clips. Hope this helps
jpcibiza90
125
scarborough
its just i fancy painting mine silver n wondered if i could still use it for owrk n stuff n still have my cdplayer workin and climate control workin
