Seems like C was dropped in May 2017:
ShopDap for example, are showing a supersession from C to Q:
On the 2.0 I can see another supersession - but also including a new filter housing!
Personally would just get some new 0-rings rather than the whole assembly - annoying when they don't list these separately.
Correct, but the newer version does not fit in the old style filter housing. I requested that version first, but the dealer corrected me, saying that version is not correct for my VIN number (and they were right).
I just realised my oil filter is under the hood, so I can check the o ring myself. If I remove it can I put the same on back in or is it recommended to put an entirely new filter ?
You can re-use it, but as filters are quite cheap, it makes sense to just replace it while you are in there
