So had it plugged in on a code reader. Was showing a misfire on cylinder 4. Not sure if could be coilpack.
But I still can't understand why the oil would be all over .
Swap the coil pack from 4 to another one see if it the fault changes to another cylinder?
I hope you haven't lost any compression... (worst case scenario...)
If your PCV is broken which mite be 50/50 then you will need to swap out the rear pcv pipe too, if your staying oem but you can use blanking plate or a catchcan and ignore the rear pipe then. (hope this makes sense?)
