chavlad
slight leak coming frm passanger side radiator dnt knw if it the rad or pipe not mch loss losing bout couple tablespoons a day is it worth trying rad weld or wil that make fingz worse
I had a tiny leak- was dropping from max to min level every 4 weeks.
put some rad weld in and no loss for a couple of months now. it is only a temp fix though.
is it definitely the rad or is it leaking from one of the pipes? i wouldnt bother with the radweld if its leaking from a pipe!
dnt knw where it frm exactly pipe n rad both feel dry jst c where drip coming roughly frm luks lyk bottom corner of rad if i put sum in it wnt block the pipes wil it
jst bought sum holts rad weld it says permantly stops leaks i thought it was temporary aswel il put it in tomorow mrnin b4 work n let u knw the results in a couple of days if no cure i take it it could only b the pipe
quick update on the leak all seams to have stoped for now hope it stays that way
