seatibiza2000
I hope someone can help...
6 months ago my Seat Ibiza 1.9 SDi Cool (X reg) developed an intermittent fault with the accelerator pedal sensor (you put your foot on the gas and nothing happened). We had the sensor replaced but the fault continued....we then discovered that the ECU had been water-damaged (fortunately water damage was limited to the ECU itself and all connectors etc seem OK).
We sent the ECU away to be re-built, refitted to the car and for 6 months there were no problems... until 2 weeks ago when the fault returned.
We sent the ECU back to the specialists who analysed it, re-built it and returned it to us. The ECU specialist has said that he detected corrupt code within the ECU which was caused by the immobiliser - he has recommended by-passing the immobiliser and has said that this will solve all issues - if we simply re-fit the ECU without by-passing the immobiliser the same error may occur.
I’ve since spoken to lots of different auto-electical specialists who all say you can’t by-pass the immobiliser, but my ECU specialist says you definitely can!!
Any ideas how to proceed or anyone had a similar issue?
Many thanks in advance!
