whitcherjoe
Hi. trying to take the seats of of my car but not sure wat to do. i have a leon cupra r i got the back ones pretty much off but can get them to split in the middle of were the to seats join. and i dont have clue on were to start on the fronts.
cheers
If you get in the back with the front seats all the way to the front you should see the covers over the runners, you need to take these off (from memory they have covers over the screws), there should be two screws per cover. Make sure you un plug the airbag whilst the seats are forward. Now if you look under the front seats (slide them back and get in the front) you will see two nuts, you need to undo these then slide the seats out backwards. Now you can either take them out the front or back door.
Back seats have a little clip / hinge hidden down on the bottom left and right of the rear bench. You slide those clips aroundwith a screw driver and it will release the seats - the middle is just a push fit connector between the two seat halves :)
