Help, used my U280 Memo scanner, these codes appeared....
antzleoncupra
227
Billericay
Hi all,
Since i bought the car in June, it had the Engine management light up. The car drives sweet as a nut, no nasty noises and i have recently driven the car to Birmingham and back and again has been fine.
So i bought a U280 and plugged it in today, the following codes come up:
17511- 02 sensor Circuit Heating Circuit (B1-S1) - Output too low
Hopefully the reason why i cant get hot heat from the climate control
17748- Camshaft/Crankshaft Position Sensors (B2) - Out of sequence
How will i get this sorted?
I cleared all the codes and the engine management light went off, until the second time i started it and its back on. Can anyone help me?
antzleoncupra
227
Billericay
where can i find the 02 sensor on the engine that its after?
Also after reading elsewhere on the forum, some suggest my timing belt could be a notch out hence the sequence error? But surely after clearing the codes wouldnt that have come back instantly? I drove it for atleast 20 miles before it came back up.
meltonlad
391
huntingdon
i know that the B1 bit is before the cat but when i looked today on my mk2 tolly i could not see any lambda sensor nor any wires.... i think im going to have to take it to the garage and get them to do it....... adding more expense. cant beleave no one can help us.
