Help with ordering BT parts
paul-murphys
efr 6758 here i come
im after some help i have chosen to use and efr 6758 to build my big turbo but need someone to help me chose my final parts i need to order,
i need a fuel pump should i go for in tank or inline fuel pump
also what size injectors should i be ordering as i thought 630cc would be ok or should i go for 750cc,
thirdly is i am ordering a SEM but need to no if i should order it with a 60/70 or 80mm throttle body?
any help will be much appreciated :D
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
whats the current state of play with the car?
Forge internals
Valvetrain
Transmission
these are all things that will need to be looked at and addressed if your going bt.
I am in the process of ordering all the bits for mine, I have gone for a 2.0 stroker and full ferrea valvetrain, gas flowed largeport head etc. It all depends how deep your pockets are and how much power & reliability you are looking for.
I would go with an inline fuel pump personally with 725 or 750 cc injectors with a turbo of that size. I have been toying with the idea of the new EFR series turbochargers as they promise imense spool with good top end power.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
70mm or R32 with SEM would flow well with the EFR I think
750cc or 830cc (3bar)
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
in-lines work well for me.. 044 or DA-31 type
N75 and mapping does your boost control.
If you fancy gear based boost control, Apexi AVC-R does this, which may be handy for high power and only fwd
