Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
What he said and for that reasonHairy said:Just for my pennies worth...
You should always take the negative off first (at least on a negative earth car) to prevent you from shorting out the battery by accidentally letting your spanner touch the engine\body work while slackening the positive terminal. When re-fitting it's obviously the reverse so fit the positive first.
cordobabrendy said:if youre removing the battery yea, if not you dont need to touch the +ive.
philtdi said:I reckon its the weather, they say anything above 12 degrees can make a diesel feel low on power!
philtdi said:AC - air conditioning. What is econ?
