Help with reset ecu
PlatinumR
Arrived and lovin it!!
Jul 23, 2004
253
Shoreham-by-Sea
Hairy said:
Just for my pennies worth...
You should always take the negative off first (at least on a negative earth car) to prevent you from shorting out the battery by accidentally letting your spanner touch the engine\body work while slackening the positive terminal. When re-fitting it's obviously the reverse so fit the positive first.
What he said and for that reason :)
Hairy
590
Wiltshire
cordobabrendy said:
if youre removing the battery yea, if not you dont need to touch the +ive.
Sorry if I was misleading, my comment was about cars and batteries in general, as you say no need to touch + for a reset.
Oct 12, 2005
1,013
Right one last question. The -ve cable is currently off and I am waiting for 30 mins. How will I no if the reset has been successful??? and is there anything i need to do once the cable is reconnected. Do i just start car as usual?
redcupratdi
Offical SCN Pole Dancer
Oct 13, 2005
755
cambridge
u won't know it is successful! might feel faster, may not! but you have reset it if left for 30mins,
just drive it hard for a day after reset!
could be a long list of things if car is serouisly down on power, could be the fuel, could be dogdy MAF, could be a boost leak.
Could be you are getting use to the power and if started to feel slow!
p.s read back on thread your answer to your last question is there ;)
Oct 12, 2005
1,013
Right its all done. Took it out for a spin and it didnt seem any different. Will see how it goes in the next few days. I reckon i am used to the power now but I still love it.
ANRO
289
Switzerland
philtdi said:
I reckon its the weather, they say anything above 12 degrees can make a diesel feel low on power!
Do you drive normally with AC on? Or if you have Climate, with ECON disabled?
Switch the AC off or enable ECON, you'll feel a sure difference.
Oct 12, 2005
1,013
Just been out 2day and it feels really good. Pulling much stronger but it is a bit cooler 2. Its back:lol:
ANRO
289
Switzerland
I know it's best to do a ECU reset when the engine is cold etc.
However, how long would one have to wait to do a ECU reset after the motor has been used?
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
anro you can disconnect it at any time really, leaving it disconnected for 30 mins will be virtually cool anyway as long as you havent been hammering it.
