Nov 2, 2019
Hi guys, can anyone else has or had problem, that under the bonnet, somwhere around air filter and brake fluid container, at idle car makes sort of squeaky noise?
It does that even when the engine is warm, when accelerate on about 1600 rpm, noise is gone, but otherwise, all the time it squeaks..
Sent from my MRD-LX1 using Tapatalk
Sorry mate, that could be many things from a tight belt, rubbing hoses, worn engine mount to a loose bracket... I'll resist the obvious mouse joke :)
All you can do is explore and carefully touch parts to see if the noise changes, obviously being extremely careful with a running engine. Good luck Sherlock.
Reactions: bigT's lcr
