Hi newbie
Hayden_93
10
Recently bought this car
cheers :)
Sent from my SM-G955F using Tapatalk
bald_eagle
yeah its blue but i like
Mar 25, 2007
529
Had something similar when my drivers door stayed unlocked,could lock it using the key manually no problem,i stuck some WD40 using the straw into the keyhole itself and locked unlocked a few times and something freed up. Mechanism still sounds a bit noisy on the drivers side but has worked again for months.
It showed up on vcds as a faulty drivers door central locking mechanism.
JamoJ
12
Faulty microswitches in door locks is a common theme across the VAG range. Mk4 Golf and B6 Passat is notorious for the same thing! New lock should sort it.
Sent from my SM-A320FL using Tapatalk
