BASH29
244
East Midlands
hi guys after some help from all of you, i have managed to source a HID kit
i was going to wait till next week before i install it but, well you know how it is, i need to get it done like now!!!!!!
ive worked it all out and just need help with identifying the positive and negative, both wires are black and unless i use a volt meter, which i currently cant find, i dont know the following
when looking at the original wiring, there are two wires entering the plug for the H& bulb, one above the other..
can anyone confirm which is positive???? top or bottom wire and is it the same for both N/S & O/S
cheers
bash
always thought it was the rh on from the rear - but dont quote me on that untested sorry - but do you have the old bulbs ?
slot it in so it's wired one side
turn lights on
touch other side to body as earth
if its wired to a positive it will light up
if its wired to a negative it will do nothing
note if it lights up it will get hot :)
if the headlight connector colours are red and brown, and the hid wires are blue and black
red to blue
black to brown
have just managed to get hold of a tester.
this might help someone in the future
o/s positive is the top wire
n/s positive the the bottom wire
cheers guys.
