HID Install help which is + & -
BASH29
243
East Midlands
hi guys after some help from all of you, i have managed to source a HID kit
i was going to wait till next week before i install it but, well you know how it is, i need to get it done like now!!!!!!
ive worked it all out and just need help with identifying the positive and negative, both wires are black and unless i use a volt meter, which i currently cant find, i dont know the following
when looking at the original wiring, there are two wires entering the plug for the H& bulb, one above the other..
can anyone confirm which is positive???? top or bottom wire and is it the same for both N/S & O/S
cheers
bash
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
always thought it was the rh on from the rear - but dont quote me on that untested sorry - but do you have the old bulbs ?
slot it in so it's wired one side
turn lights on
touch other side to body as earth
if its wired to a positive it will light up
if its wired to a negative it will do nothing
note if it lights up it will get hot :)
gazR
CUPRA
Apr 25, 2009
458
Derbyshire
if the headlight connector colours are red and brown, and the hid wires are blue and black
red to blue
black to brown
BASH29
243
East Midlands
have just managed to get hold of a tester.
this might help someone in the future
o/s positive is the top wire
n/s positive the the bottom wire
cheers guys.
