ibiza1.8t-cupra
52
20
Today I made a home made boost leak tester, from 2 tin cans, and a £2 Schrader valve and it worked well.
Pumped it up with the small Ring tyre compressor, in under 1 min was up to 10psi, then switched off.
Psshh noise from diverter valve area, pressure reducing, sprayed it with soapy water, the alloy aftermarket, no brand, diverter valve has cracked where the hose connects going into it. Must be loosing boost there, anyone had a alloy dv crack?
Reactions: Syphon
