Honda S2000 filter on remapped AUQ.
paulos44
537
Warwickshire
Just took the car for a spin after fitting and to say i am disappointed is an understatement. It feels less powerful than it was before the CC Stage 1 remap. As soon as i had stopped i pulled up the bonnet and the filter felt cool to the touch,which seems to rule out heat soak.I am wondering whether there is something else i need to do.....new exhaust with sports cat?... .to complement the filter. Also,the blow off noise is a lot louder than it was...i am totally confused.
Feb 1, 2007
1,602
Nottingham
The recirc noise will be louder if you have fitted an open cone!!
Its just not matched to the AUQ engine, the flow rate is obviously wrong?
Scorponok
75
DEVONSHIRE
If the car was pulling ok before changing filter bung the old filter on and see if that eliminates anything. Check make sure you haven't accidentally knocked something or taken something off by mistake.
Dump valve noise will increase with a cone filter mate
paulos44
537
Warwickshire
No one is suggesting that the filter is restrictive....quite the opposite.The same happened on my old Primera when i fitted a cone.However,that car had a learning ECU and within a few tens of miles it was running a lot better than original. Does anyone know whether the AUQ has such an ECU?
traumapat
Leon Cupra IHI
Jul 24, 2005
5,917
sunny sussex
Yes the ecu does adapt and learn over time.
What expectations did you have?
Check everything you touched to make sure its secure.
paulos44
537
Warwickshire
I expected at least the same performance as with the standard airbox. I have double checked everything and all clamps are secure. Also, i am still not convinced about this sucking hot air in business that has been mentioned. Half a dozen times i have lifted the bonnet immediately after a good blast in the car and the filter is not warm in the slightest.Admittedly,a cold air feed would be better but i think the hot air problem is somewhat exaggerated.
I am gonna whip the filter off tomorrow and put the standard box back on.In the meantime,i will make some sort of cover for the filter with a 3 inch cold air feed.....
paulos44
537
Warwickshire
Forgot to add...i read somewhere on the web last night that a combustion engine can never have too much air going into the intake ,only too little fuel to mix with it which will cause a power drop. This has got me thinking that maybe the MAF can only work within certain parameters as set during development of any particular engine.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,917
sunny sussex
With turbo cars the main air cooling is done with the intercooler but it still pays to run a shield if only to stabilise the maf which hates vibration.
Did you disconnect the battery when you fitted it?
I think your right about maf reading within certain parameters but as far as I know their well within the scope or usual remapped power.
What fuel are you running?
traumapat
Leon Cupra IHI
Jul 24, 2005
5,917
sunny sussex
You could try disconnecting the battery for 30mins , it will reset the ecu so it starts with a clean sheet. Make sure you have your radio code if fitted.
paulos44
537
Warwickshire
Well...i disconnected the battery earlier for an hour and what a difference.....all the power is back,only seemingly with more urgency than before.I havent really opened her up today but i will be giving her a good seeing to tomorrow...lol...especially as i put fresh 5w30 in last week.
