Drop the steering wheel down to lowest position and you will see two screws inside the top of the instrument binnacle. Remove these and gently prize out the plastic surround from the binnacle - then you will see two more screws ( one either side of the instrument cluster ) remove these and again gentley persuad the instrument cluster out remembering that it has two multi plugs connected to it. Remove these multi plugs, this allows cluster to be released from the car. If you are changing the bulbs in the cluster they need to be turned 90 degrees to be removed. Re fit is as they say the reverse of removal.
i think the clocks might be on there way out as they do not dim down anymore but the center consol still does???????????
any idea how much a set of clocks are?
