Is this the right cable to go in the back of the double din units?
Its ebay item 270727493449
I am a posting pawper, so can't post the link yet. Sorry.
It doesn't look right to me? Not for the mark 2 toledo head unit anyway.
OK, a few pics...
First, the radio keys and where they fit, for those who haven't yet looked at removing the unit. Ebay special, set of four for a couple of quid. I've actually found I only need two two remove my unit, I'm sure it did need all four at some point.
Then the pinout;
(Sorry it's a bit blurry, the flash just made everything flare up and I can't figure out how to decrease the exposure without the flash)
Now the important picture, the back;
The lead I bought for the audio in is the connector to the right, with heat shrinked insulation leading to a pink wire (live), red and black (audio). That's at the top of the picture. The red and black go off into a little white box, which is my home made pre-amp. The pink comes back on to the wiring loom and is spliced into a live wire (in this case it's actually the CD changer 12 volts which was the easiest to get to).
The wire sticking out of the connectors is the gala wire, a blue and white wire that now goes nowhere. The other end is terminated with a bit of insulation tape so it doesn't short on the casing.
And lastly, the all-important menu option;
As you can see, the TV/VIDEO option is available.
