benwalllker
im wanting to get all the pillars/ a/b and rear, and headlining out along with door cards and rear fabric patches. to swade them up and make them look pretty lol. has anyone posted threads on how to remover this lot?? if so and anyone knows were they are could they link them, cuz i cant find anything apart from the guide on taking the door handles out which helps. or if anyones done this already could you give me sum support with (its easy, yook me two minutes) or summit nice anyway :)
cheers
Its pretty much straight forward mate with removing it. All screws ar visible so can simply just remove them all and most of the liners just pull off. If there are no screws then its clips.
My motto is... if its not coming off after a few tugs there is still a screw somewhere...
you can strip the car in just under an hour
remoce all the jesus christ handles (theese are screwed in) then everything else just pulls off excepet the seat belt ones as iirc you have to undo the seat beat fastening same at the rear
then pull
and that motto is spot on :D
i striped my cupra in 20mins and then redone headlineing in black carpet and then pillars in leather well worth doing pal. tommy has all mine now . also it keeps ur car warmer
well after all that who needs a guide, thanks all. hopefully should get on that fairly soon then :)
