it will fit but you would need a new manifold , tip , injectors, downpipe ,oil and water lines , larger maf ,and a bigger intercooler and a updated map to get the best from it !
worth doing if you can get the bits for a good price but it not a simple turbo swap , not worth doing if your going to buy the parts new due to the cost
you might get away with using some of the oil and water lines as the fittings are the same.
