Do you turbo guys leave your engine running after you stop? I heard after you have put your foot down a little your meant to leave the engine running incase the turbo burns out, from not cooling properly?
I always try to let mine idle for 30 seconds or so before cutting the engine. But like Steve i try not to place too much strain on the engine for the last mile or so before i get to work.
Turbos use engine pressure to draw oil up over the bearings for lubrication. With the engine cut off they lack the necessary pressure to continue supplying oil to the bearings which is bad if you've been thrashing the engine and the turbo is still spooling down.
This used to be a common problem on alot of police cars which all ended up in the shop for repairs as they'd thrash the engine chasing crims and then when hopping out to give chase on foot, they'd switch the engine off suddendly whilst the turbo was still turning.
However, like chris said, this problem has been rectified on most new cars, with the addition of an auxilery coolant pump. I just never trust it to lubricate properly and always try to give my engine time to cool properly before killing it.
Mike.
Always granny drive the last few miles home![]()
How long should I leave engine running before switch off?
I would say - make sure you are at least at your destination.
there is no way id say use a turbo timer... lots of legal and insurance issues and when your car rolls down a hill cause you cant leave it in gear you will be sorry.
Are there insurance problems if you do not leave your car in gear on a hill? I never do this.
