You must power bleed. (The fluid is shared with the brake system from a single reservoir) The bleed screw on the clutch slave is just forward of the shifter mechanism on the geabox.
Thanks for the info Dave, I assume soon as the brake filler resevoir is pressurised undo the bleed screw until new fluid comes through, any idea how much the gearbox capacity is, being a little lazy, I should look it up I know.
Ian
