Before looking at part numbers, it is important to understand why this check matters.
SEAT and CUPRA cars can have few different sound-system layouts.
The basic sound system does not have a separate external amplifier. The amplifier is built into the MIB multimedia unit itself. If the screen, navigation and Bluetooth still work but there is no sound, the fault can be inside this unit.
Higher-spec sound systems use a separate external amplifier. In these cars, no sound does not automatically mean that the MIB unit has failed.
This is why we need to identify the unit and its rear connectors before deciding on the repair route.
First, look for a separate amplifier. On some SEAT and CUPRA models it can be under the front seat: usually the driver’s seat in LHD cars, or the passenger seat in RHD cars.
Then look at the rear of the MIB unit.
If there are optical MOST fibre cables connected, the car will often have a separate amplifier. If there are no optical cables and no separate amplifier, it will usually be the basic sound system with the amplifier built into the MIB unit.
There are exceptions. Sometimes a unit has MOST cables but also has normal speaker-output wiring. This can be a mixed setup and may still mean that the unit has an internal amplifier. Do not rely on one connector alone — send clear photos if you are unsure.
After this, check the label on the main MIB unit. The important details are:
  1. Manufacturer name
  2. OEM part number, usually beginning with 5F0
  3. Rear connectors
If you are unsure, post a clear photo of the label and rear connectors, together with the car model and year. We can help identify which system you have before you spend money on the wrong repair or replacement.
