AlperUtkuCeylan
85
37
Good forums for everyone,
There are times when there are too many trim sounds in my SEAT Ibiza car. What solutions do you have for reducing such trim sounds?
I am currently trying to reduce it with würth silicone spray, but not all of them are reduced by this method.
Hello! There are a few strategies you can try beyond silicone spray:
  1. Check Fasteners and Clips: Loose or worn clips are a common cause. Replacing them with fresh ones can make a big difference.
  2. Use Felt Tape or Foam Padding: Apply it between panels where noise is coming from. It’s a cheap and effective way to dampen vibrations.
  3. Inspect Door Seals: Sometimes, noise can come from dried-out or misaligned seals. Reconditioning them or replacing worn ones helps.
  4. Tighten Screws and Bolts: Check under seats and panels for any loose hardware.
If you find that a specific part is causing excessive noise and needs replacing, I’ve had success finding cost-effective options through used auto parts suppliers (i like this one: https://www.b-parts.com/). It might save you money if it’s a larger component causing the issue. Best of luck silencing those rattles!
Reactions: nd-photo.nl
Pretty much this what @David.Pierre wrote. I had an annoying rattle in the dash, which was resolved with tip number 2.
More info: https://www.seatcupra.net/forums/th...-leon-st-cupra-280.477591/page-2#post-5068932
AP1GczMV_NjcAnMfToclkGMt7d-UErVWqqqszLboxs4VIC0OZGz1Jophxx1JtNu2LYa0sWdug481REmg9tqkRLSxD80i4AkAEoNlYQo_UN1kakJu4GSmM_hUsmq9A-w2ifROaEcTrOA2lvTcqZKjxx0webnSeA=w1920-h1080-s-no-gm
Another one by using tape (backseat bracket rattle)
AP1GczOcJHOoZJ61rnPvTXjGiY0eujcKrLwS-rOH6mxFVqFSj3iajRQgTjZiLF7bo9zeqa76m7mrthHHRBfKiVeW-_eYCiCuO4TyBTk0byfz8tHTmpLggRr0JALsjgV7RZNC3uJEUu8-8ysHjPorCRnWvSK0OA=w1920-h1080-s-no-gm
