I dont think changing requested values will do much tbh. If the turbos going to produce 1.2bar at 6500, it surely doesn't matter if ecu is requesting 2000mbar or 2400mbar at this rpm.
You fitted yours yet Carl?
I'm not sure about that mate, i suppose it depends on the duty cycle but i thought the ecu would need to be requesting more to get the best of the turbo. :shrug:
have you logged the duty cycle recently.
:redface: and still no turbo fitted on my car yet, but i'm looking forward to it.:)
Nope not logged duty cycle for a while now.
Will have another play at weekend i think
As to requested values, yes i do agree that requested should always be above actual to get the best from the turbo. The wastegate should be working at a harder duty cycle to meet these requested values.
JBS is a 110mile 1 way trip for me, but the next time im back James is going to have another look at the map to see if it can be improved. I still need to have a fiddle with custom settings but at moment still trying to source a cable.
Here is some a actual vs requested I took last night (4th gear runs):
Code:
Group A:	'115
	RPM	Load	Absolute Pres.	Absolute Pres.
TIME
STAMP	 /min	%	 mbar	 mbar
32.24	2840	35.3	1010	1070
32.64	2880	84.2	2500	1170
33.04	2960	106	2440	1510
33.56	3160	151.1	2490	2060
34.05	3400	191.7	2550	2540
34.45	3640	191.7	2550	2540
34.85	3840	191.7	2550	2540
35.25	4000	191.7	2550	2540
35.67	4200	189.5	2550	2540
36.07	4400	187.2	2550	2540
36.47	4600	182	2550	2540
36.87	4760	175.2	2540	2540
37.27	4920	174.4	2510	2500
37.67	5080	177.4	2480	2430
38.08	5240	176.7	2440	2390
38.48	5400	175.9	2410	2320
38.98	5600	163.9	2370	2310
39.38	5720	154.9	2350	2350
39.78	5840	157.1	2310	2260
40.19	6000	154.1	2280	2230
40.6	6120	149.6	2260	2210
40.99	6240	151.1	2250	2240
Block 118 with N75 duty & inlet temps:
Code:
Group A:	'118
	RPM	Temperature	Load	Absolute Pres.
TIME
STAMP	 /min	°C	%	 mbar
100.41	3160	23	0	1380
100.81	3280	23	95.3	1660
101.21	3480	24	87.5	2320
101.61	3680	24	83.1	2540
102.01	3920	24	83.1	2540
102.42	4120	24	83.1	2540
102.92	4400	24	83.9	2540
103.41	4640	24	84.7	2540
103.83	4840	24	87.1	2490
104.23	5000	24	88.2	2480
104.63	5160	25	90.6	2420
105.03	5320	26	94.5	2330
105.43	5480	26	95.3	2260
105.94	5680	27	95.3	2220
106.34	5800	27	95.3	2240
106.74	5920	28	95.3	2240
107.14	6040	29	95.3	2200
107.54	6160	29	95.3	2200
108.05	6280	30	95.3	2240
108.45	6400	30	95.3	2250
108.87	6480	31	95.3	2220
Nice Figs, Glad too see you've got acess to vag com. They look very similar to Mitchy's. The Hybrid is a full 0.1 bar better than the stock k04 at the Red Line.
Are you going to any RR meets this year for some updated figs.
