do you eric or somebody else got the code numbers for the koni fsd and the eibach's;;if i order them here in greece i want to be sure i order the right ones.:)
I don't have the codenumber for you but when you order Koni FSD dampers for a Leon II you will get the right one's. (That's how i ordered them)[B)]
All this kit can be fitted using a jack and usual tools as long as you have a reasonable understanding of what your doing .
took about 3 hours to do mine
Always well worth taking the car for a geometry check after you fit new suspension, to make sure everything is sitting level. Tyres are expensive when they wear out unevenly.
Most places charge around £30 to £40 if memory serves, but everything is laser aligned and adjusted if need be.
eric you mean that all leons from 1.4cc to cupra wear the same dampers(according to koni anyway)?!?can that be true?anybody please about the eibach's code?thanks!
Forgot to say that zboyd .Though did let mine settle for a few miles before taking it too northamton motorsport for a full geometry check.:D
I ordered the Koni's for a Leon II FR, as there was no seperate damper for the
Cupra. I don't know if this damper is the same as for the other Leons.
1.4 leon ?
most aftermarket suspension equipment is designed on axle weight as you are upgrading
so most of the models will be about the same weight they will use the same equipment unless there is a physical mounting difference which is unlikely these days
It is interesting that the cupra is 41kg heavier than the fr :confused:
