Thought you may want to read what I wrote as I know its a pet hate of a few people on here:
We'll see what comes of it.
I thought I’d write you a letter to let you know how ridiculous verging on dangerous the kick down feature in MANUAL MODE is on my new Ibiza Cupra Bocanegra 7-speed DSG gearbox.
Now I understand to a certain extent why the box would auto change up or down (as opposed to KICK down) to protect the box if the driver is incompetent etc but for the kick down button to still work in manual mode is ludicrous. If I put the car into manual mode on some nice country lanes I’ve done so because I want to drive the car and don’t want rev the guts out of the poor thing like it does in the frankly pointless “sport” mode.
Seat, or more accurately VW engineered the engine and the box so should know better than anyone the power band. What is the point in the thing reving all the way to the limiter when it’s quite clearly out of the powerband and can’t be particularly good for the engine?
Anyway the reason I was prompted to send this email was an instance last night:
I had entered a long sweeping bend had the car in manual mode and was in the perfect gear for the corner. I’d reached the apex so was now accelerating out the corner I was now around 5000rpm as the road straitened I INTENDED to go full throttle before changing UP.. Unfortunately the DSG thought better off this and kicked the box down a cog and sent the revs up to 6000/6100rpm... This had the effect of making me think the pistons were about to exit the engine via the bonnet, made me look rather silly for reving the car pointlessly at the end of another wise perfectly smooth corner and sent the car off balance as it was now out of the powerband . WHY? Why would the DSG’s ECU possibly think at kick down at this engine speed was a good idea?
I propose what I presume would be a rather simple ECU software change/edit which would eliminate this problem completely. Ether A) remove kick down from MANAUAL mode completely or look at the parameters at which the box will kick down to which gear from a given engine speed to something slightly more realistic. I gave up on sport mode due to this reason a long time ago, I don’t know why but changing up on a corner when the engine is at a safe RPM on the rev range without my permission just does not sit well with me..
Its not all doom and gloom “Drive” is fine and works great at keeping the economy up and does a pretty good job at adapting to the drivers style. When the box is doing what its told and I haven’t accidently hit the “All Hell Break Loose” kick down button the gear changes are also swift and smooth and it’s a joy to flick up and down the box with the paddles.
So Seat/VW I beg you please have a look at the software and sort out a problem that was not only picked up in most media reviews of the car but is also driving 7-speed DSG drivers up and down the country a little loopy!
As a side note I have posted this on the seatcupra.net forums so you can track the wider response to this on there if you so wish.
Regards
Mark Donkin
