Hello all, can anyone inform me that if the 1.4 mpi AUD engine is belt or chain driven? having a few temperature issues, bit erratic and strange really.....
heats to 90degrees and then after about 10 mins or increased speed the gauge will rise, but occasionally will drop right back down to 60, i had a similar prob on a leon cupra that turned out to be the coolant temp sensor, could this be the same? are they as prone to failing as the leons? ive got a thermostat to fit and it also seems as if expansion tank is slightly cracked so that will be done asap,
lad that i bought it off was told the waterpump on it may of failed? is this likely and thats mainly why i asked if its chain or belt driven as i know the chain driven ones have a auxillary belt driven water pump on them,
All help is greatly appreciated
