az101
87
14
Burnham-on-sea
I have just bought a Candy White Bocanegra
Its lush! only a few small issues with it, and one of these is, the Xenon headlgihts dont auto level. Ran a Scan on the car with VCDS and it has reported back as below. Anyone able to help? I am aware this doesn't have the proper front bumper, as it was was Cat C repaired (Got a good deal) however i think they have buggered somthing up while repairing :confused:
By the way i have Vag Com if anyone needs a scan in the Burnham / Weston Area, Somerset :)
Chassis Type: 6N0
Scan: 01 02 03 08 09 10 15 17 19 25 44 4B 55 56 77
VIN: VSSZZZ6JZAR087699
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (------CAVE) Labels: 03C-906-027-CAV2.clb
Part No SW: 03C 906 027 AE HW: 03C 906 027 AD
Component: 1.4l R4/4V TS H10 7931
Revision: L2H10--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 02021 210 88177
ASAM Dataset: EV_ECM14TSI01103C906027AE 001002
ROD: EV_ECM14TSI01103C906027AE.rod
VCID: 64CDB2496F409E9
2 Faults Found:
4344 - Please Check Fault Codes in Control Module for HVAC (J301)
U1025 00 [047] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 51468 km
Date: 2045.14.18
Time: 15:18:13
4715 - No Communication with Instrument Cluster
U0155 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 51468 km
Date: 2045.14.18
Time: 15:18:13
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 048 S HW: 0AM 927 769 D
Component: GSG DSG AG7 402 1805
Revision: 00040024 Serial number: 00000910300629
Coding: 0000020
Shop #: WSC 06402 785 00200
VCID: 40855ED91098E29
No fault code found.
Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ESP.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 130248DB837500B9C82B12EBC1DA00811700
Shop #: WSC 04941 000 00000
VCID: 4D9B77ED10CA3F1
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 6J0 820 043 A HW: 6J0 820 043 A
Component: Climatronic H07 0404
Revision: S0000000
VCID: 2241F4513DD4D09
3 Faults Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 93
Mileage: 48752 km
Time Indication: 0
Date: 2108.14.23
Time: 17:47:49
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 93
Mileage: 48752 km
Time Indication: 0
Date: 2108.14.23
Time: 17:47:49
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 91
Mileage: 51463 km
Time Indication: 0
Date: 2109.14.18
Time: 13:49:31
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 304090449
Coding: 3C8829E888612500932800007E0B1FC800C0420F608C0000200000000000
Shop #: WSC 64564 324 38760
VCID: 3E792021A96C949
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 111109 05 54 0402
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 802 A HW: 6R0 959 802 A Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 001 0250
Coding: 030000
Subsystem 3 - Part No SW: 6R0 959 801 C HW: 6R0 959 801 C
Component: J387__TSG_BT 001 0254
Coding: 020000
Subsystem 4 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Coding: 000000
Subsystem 5 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Coding: 000000
Subsystem 6 - Part No: 1K8 951 171 A
Coding: 000000
Subsystem 7 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 010000
1 Fault Found:
00910 - Indicator Lamp for Emergency Flashers (K6)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 175
Mileage: 39935 km
Time Indication: 0
Date: 2110.14.03
Time: 12:05:26
Address 10: Park/Steer Assist (J446) Labels: 6J0-919-475.clb
Part No SW: 6J0 919 475 A HW: 6J0 919 475 A
Component: PARKHILFE 4K H07 0007
Revision: -------- Serial number: 80320928800996
Coding: 000106
ASAM Dataset: EV_SE250ParkiAssis2 S01006
ROD: EV_SE250ParkiAssis2.rod
VCID: 346D02099F204E9
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagA05 H09 0018
Revision: -------- Serial number: 003DW008AYKY
Coding: 003035
Shop #: WSC 06401 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 428154D1D594F09
Crash sensor for side airbag; driver side:
Serial number: 3496GRB402H9MGGKQ3GC
Crash sensor for side airbag; passenger side:
Serial number: 3506GRB40239V7KGS3N%
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 901 E HW: 6J0 920 901 E
Component: KOMBI H08 0110
Serial number: 00000000000000
Coding: 410A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2A511C714DE4089
1 Fault Found:
13639168 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 141
Mileage: 40491 km
Date: 2046.14.05
Time: 12:56:39
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 422100
VCID: F0E54E1923B8B29
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 93
Mileage: 32178 km
Time Indication: 0
Date: 2097.14.12
Time: 19:15:47
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H08 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 10110
Shop #: WSC 00000
VCID: 30650E19F738729
Address 4B: Multifunc. Module Labels: None
Part No: 6J0 959 441 A
Component: MF-Modul 0007 0001
Coding: 0000002
Shop #: WSC 77005 000 00000
VCID: 31630B1DA8327B1
Address 55: Xenon Range
Cannot be reached
Address 56: Radio (J503) Labels: 6J0-035-153.clb
Part No SW: 6J0 035 153 B HW: 6J0 035 153 B
Component: Radio G3 UL H58 0058
Revision: 0H001001 Serial number: SEZ1Z2I6335818
Coding: 0501040002
VCID: 234FF15522CED91
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E
Component: FSE_2P8x H40 0190
Revision: 00000000 Serial number: 00000005109809
Coding: 0010720
VCID: 3A712C317544B89
End ---------------------------------------------------------------------
Thanks Big Pete, have booked it in for a check up next Monday. Have joined the FB group,
Biker, Im fairly sure its the Xenon headlights, as they take a min to get up to brightness and are really bright compared to the ones from my Leon. also they are like little crystal balls sat in the headlights :) Yeah pics aren't great snapped them on my phone just after i picked it up :D
Do you know the extent of the damage/repairs?
If they can't be bothered to fix the bumper right I would be worried about what else is going on. The sensor/whatever it is for the Xenons auto level is on the rear axles near one of the hubs if I remember right.
Definately Xenons though!
Thought they had two sensors, one at the front and one at the rear?
But yeah I'd be concerned as to what else hasn't been repaired properly...
I was going to say isn't there something at the back of the bay below the charger where the exhaust brackets are but I wasn't 100% sure but I'm almost 99.9% sure there's one one the rear attached to one of the hubs or close to the hub.
If it's a Cat C check the driver side wishbone for the auto leveller it should look like a funky little green plastic thing but if the crash broke the wish bone any bet they didn't fit the auto levelling sensor back?
Im afraid i don't know the extent of damage or repair. But its definitely had a new front bumper / bonnet.
Will see if i can whip the front wheel off later and have a look if i can see anything there, ill grab some pics if i can. Didn't have a chance to look last night, was out till 3am fitting a HID kit in a Golf V for a mate. That was a PITA.
So dropped the car to Seat Monday, and They have now sorted the headlights. It was a fuse apparently :)
I thought i checked the fuses but oh well. SO as i cant pick it up will Saturday they are going to sort the Air Con out as well. Then ill have a slightly healthier car :D
I don't know if it's just the angle your pic was taken from but there seems to be a bit of a gap and weird spacing between the bonnet and the front?
