Ibiza cupra 2016 1.8T IC unit upgrade ?
Quiksilver
243
Hi All,
I have read the thread about the older models IC unit change and I wonder if we have the same body kit? same OEM IC unit?
From my search on the web I got this OEM PN - 6R0145805C / 6R0145805F which gave me this reasult -
http://www.ebay.co.uk/itm/INTERCOOL...-OE-6R0145805C-6R0145805F-NUEVO-/171778826724
As you can see the dimensions is a little bit different than the one on the sticky thread...
Core size 550 vs OEM 617(while I guess core size can be different what can't is the overall size?)
Depth 65mm vs OEM 96mm ( for this I have no clue why)..
Can any one advise ?
P.s.
After short conversation with Forge I got this specs from them -
Core size - 606mm , height - 145mm, depth - 70mm
3 bar max, 250hp
Thanks,
Asaf.
Quiksilver
243
Okay so Today I decided to measure the original I unit and the space that I have available for an upgrade.
So here is the result:
Original IC unit -
615x~100x~71.5 (see attached pics)
Available space is a little bit tricky as I don't know what will happen with the left side...
Up to the plastic bridge I have 180mm from the OEM IC unit...
So correct me if I'm wrong but the max size I can fit will be 550x280x64 (if by lower core size it won't get to the radiator bump?)
*attached pics...
Please advise :)
