Ibiza MK4 1.8T Cupra Gearbox Query
jay87
290
Hi guys,
just a quick one, will a mk4 golf agu 5 speed gearbox fit?
Thanks guys
jay87
290
or if you could recommend any other 5 speed box from a 1.8T which will go?
jay87
290
So the gearbox off a 1.8t 5 speed golf has fit on, drive shafts all fit etc, only issue is the top gearbox mount does work with the body. Any advise on how to over come this?
Modify the bracket?
Custom bracket?
jay87
290
Theres seriously no body with any advise?
The box gone in is a 02J, the original mount won't slide on to the gearbox section as the gearbox section is too chunky
jay87
290
How did you get on? I had this problem and the bracket had to be cut and re-welded, can get photos if you want.
hi mate, yeah done the exact same thing, my dad got the bracket cut and welded to suit, drives spot on
jannerboy
49
Hi Pete,
Would you have some pics of the mod you made please as I'm in the same boat!
Pete.
325
Aberdeen
I had a look and couldnt find my photos of the mod, cars currently in the garage and i wont be getting it back till next week. if your really needed them i could maybe drive out to it over the weekend take some photos.
jannerboy
49
Hi Pete. No rush but yes as and when would be very helpful. Golf 02j fitted ok then? Ratios better?
jannerboy
49
jannerboy
49
Wow! Who built the box for you? Much much stronger I guess and ratios for quicker acceleration ?
Pete.
325
Aberdeen
its built by Sqs they supply the gear kits but will build the box for not much extra.
My old box gave up so just wanted something I knew would take the abuse.
jannerboy
49
Hi Pete,
Massively appreciate this as we need to re-build a box to take abuse, especially the GF who has no mechaincal sympathy whatsoever!
Did you also fit a LSD ?
Pete.
325
Aberdeen
check out SQSracing website they have a few different options for building a strong gear box
my SQS box has a plate type diff,
with my old box it has a wavetrac diff in it
