I have a mk5 Ibiza having trouble with my drivers side electric window , it’s a problem which comes and goes , basically when I lower the window it stops then locks out won’t go any further , I have to pull the fuse which resets it then I can raise the window up but then sometimes the window stops at half way or goes to the top and goes back down , I’ve reset the one touch on the button countless time it’s works for 4-5 up and downs then stops again , I’ve silicone greased the window shunts and made sure the shunts are clear they seem fine . Also my key fob will not operate the windows if I hold the lock/unlock button ..
Sorry for the essay has anyone had this issue before ?
