I have pasted below the procedure for measuring the urban driving cycle. However, I can't see my car achieving it's claimed urban figure if I was to follow this procedure.
The european driving cycle seems suspect and it wouldn't surprise me if car manufacturers are cheating.
Urban Test Procedure:
The Urban Driving Cycle, also known as ECE R15 cycle, has been first introduced in 1970 as part of ECE vehicle regulations; the recent version is defined by ECE R83, R84 and R101. The cycle has been designed to represent typical driving conditions of busy European cities, and is characterized by low engine load, low exhaust gas temperature, and a maximum speed of 50 km/h.
When the engine starts, the car pauses for 11 s - if equipped with a manual gearbox, 6 s in neutral (with clutch engaged) and 5 s in the 1st gear (with clutch disengaged) - then slowly accelerates to 15 km/h in 4 s, cruises at constant speed for 8 s, brakes to a full stop in 5 s (manual: last 3 s with clutch disengaged), then stops for 21 s (manual: 16 s in neutral, then 5 s in the 1st gear).
At 49 s, the car slowly accelerates to 32 km/h in 12 s (manual: 5 s in 1st gear, 2 s gear change, then 5 s in the 2nd gear), cruises for 24 s, slowly brakes to a full stop in 11 s (manual: last 3 s with clutch disengaged), then pauses for another 21 s (manual: 16 s in neutral, 5 s in the 1st gear).
At 117 s, the car slowly accelerates to 50 km/h in 26 s (manual: 5 s, 9 s and 8 s in the 1st, 2nd and 3rd gears, with additional 2 × 2 s for gear changes), cruises for 12 s, decelerates to 35 km/h in 8 s, cruises for another 13 s, brakes to a full stop in 12 s (manual: 2 s change to the 2nd gear, 7 s in the 2nd gear, last 3 s with clutch disengaged), then pauses for 7 s (manual: in neutral with clutch engaged).
The cycle ends on 195 s after a theoretical distance of 1017 meters, then it repeats four consecutive times. Total duration is 780 s (13 minutes) over a theoretical distance of 4067 meters, with an average speed of 18.77 km/h.
