Ibiza Not Starting
d1983
Hi
Have a 1996 Seat ibiza and its not starting,i have two questions....
How can i test the ignition coil with a multimeter?
Is it possible to flash the fault codes on the dash?
Thanks for your help :think:
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
you'll need a reader for fault codes, something like Vag-com is best
Coil itself carries the amplifier below it so you will need to open the cover under the coil lead to check the coil itself specifically
wiring plug (3 wire) with ignition on will show battery voltage across both outside terminals (1 & 3) -ve & +12v
wiring plug (3 wire) terminals 2 & 3 will flash an led test light on cranking briefly
2 low tension terminals (under small cover) resistance = 0.5-0.7 ohms
2 low tension connectors (under cover ) will flash an led test light on brief cranking
high tension (where lead fits on) & one low tension (under cover) = 3000-4000 ohms
bear in mind there is 2 types of coil + amp one has the units fixed together and the other they come serperate so don't just grab the cheapest one until you check first what type ya got
d1983
Thanks a lot,will give that a go.
Do they use a standard obd connector or what? :confused:
d1983
the two main things i want to check out are the coil and distributor/hall sensor,any info you have for testing those would be great,i will be getting a code read done too.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
connector is a standard obd ye - take the drivers side glovebox out and look to the left just inside the hole - more or less looks straight at the side of ya left knee if it helps
coil is more common than i car to mention - after 4 yrs of luck mine went only 2 weeks ago- very annoying
what symptoms have you got with the car ? no firing? checked fuel etc ?
d1983
Had a quick look a few weeks ago,it wasn't getting spark,can't remember about fuel :rolleyes: but plugs seemed dry as far as i can remember.
Not sure what would stop spark and fuel,don't think it has immobiliser :(
It turns over ok,just doesn't start up.
Ronnie
mine done that and it just turned out to be a fuel pump relay lol
