Ibiza tailgate won't open
Davidibiza
19
Worcester
My 2008 Ibiza tailgate won't open, I can hear the actuator working when the button is pressed and it also won't unlock when I use the key in it. Any ideas?
RUM4MO
8,104
1,118
South Scotland
Maybe try using the search function on this section of this forum and on the MK5 section, as there have been a few threads on this topic over the past few months.
MarkTDI
19
East Yorkshire
I had the same problem with my 2006 Ibiza,
search you tube for " Seat Ibiza boot lock stuck closed " and there is a guide.
On my car the actuator mechanism was slightly loose and also needed lubricating, I held the actuator in a better position with some tie wraps and it is perfect now.
Getting the trim panel off and back on was a bit of a fiddly job as the clips break easily.
Good luck :)
