Ibiza TDI not starting!!
Guizado
219
South West London
Hi guys got a big problem with my Ibiza TDI its the Sport 110, was going along fine the other day, changed gear dropped clutch and the car died and now the car wont start.
Scanned it with VAG-COM and only thing i got was
Address 01: Engine Labels: Redir Fail!
Controller: 038 906 018 GM
Component: 1,9l R4 EDC 0000SG 2162
Coding: 00002
Shop #: WSC 31480
2 Faults Found:
17958 - Charge Pressure: Control Deviation
P1550 - 35-10 - - - Intermittent
18025 - Glow Plug Pre-Heat Indicator (K29): Open or Short to Ground
P1617 - 35-10 - - - Intermittent
Readiness: N/A
The first one is a Limp mode problem I have had for a while that only comes very rarely.
And I dont think the second would cause this problem.
This is what the car does once I try to start it
http://youtu.be/b2LvyxP-ddE
Since VAG-COM didnt show up with any clues I am abit a miss here.
Anyone that could help?
Many Thanks
vaughant
Sorry to say but that sounds pretty serious to me mate, it's not even trying to turn over. Before you go any further take your timing belt cover off and check the belt is ok, if it looks ok turn it over by hand (may need to remove glow plugs) and check the timing hasn't slipped a few teeth. It really sounds to me as though something is preventing it from turning over. Hope it's nothing major.
