Errors Errors Errors! and not starting all the time
ballsack
15
1.4Tdi BNV
A few things going on - namely the car has been difficult to start sometimes, taking several attempts. It was showing this error
16706 - Engine Speed Sensor (G28)
P0322 - 35-10 - No Signal - Intermittent
I cleared the error codes - fitted new glow plugs as I believe they've never been replaced all was well for a few days then wife reported that she struggled to start it, the steering went funny and the check engine light came on. We now have the following:
3 Faults Found:
17911 - Load Signal from Alternator Term. DF
P1503 - 35-10 - Implausible Signal - Intermittent
16725 - Camshaft Position Sensor (G40)
P0341 - 00-10 - Implausible Signal - Intermittent
2 Faults Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 25
Reset counter: 32
Mileage: 177858 km
Time Indication: 0
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 178252 km
Time Indication: 0
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6L0 820 045 C
Component: Klimaanlage X00.8
VCID: 2858608FC8E0BC7E35-50E6
2 Faults Found:
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
00705 - Relay for Coolant Fan; Stage 1 (J279)
31-00 - Open or Short to Ground
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
1 Fault Found:
00566 - Steering Assistance Operation
27-10 - Implausible Signal - Intermittent
ballsack
15
As there are so many faults suddenly being reported I'm wondering if there's a single underlying issue?
RUM4MO
7,827
1,001
South Scotland
I'd guess, just a guess, that you need to check out the charging system in that car - that would be battery, alternator and interconnected wiring including load sensing wiring and excitation wiring - after checking/sorting that lot out, clear all logged faults and take it from there.
ballsack
15
Sounds like a plan. I think I'll send it to the autospark this week
R3k1355
1,785
251
Yorkshire
Dying battery gives out tons of weird error messages, they ain't real.
Replace the battery and they all go away.
ballsack
15
Been to the autospark, replaced Crank sensor and that's got rid of that error but it still doesn't always start. It's reporting cam sensor though so perhaps that next.
R3k1355
1,785
251
Yorkshire
or the battery
battery
battery
battery
battery
battery
battery
battery
battery
battery
Is there and echo in here?
ballsack
15
I did mention it again to the autospark He thinks it's fine and the error its showing could be caused by the constant cranking when it refuses to start.
alexh
61
I also got weird errors when my alternator stopped working and the battery voltage dropped lower and lower. It also wouldn't start.
What's the battery voltage?
ballsack
15
I haven't checked the voltage personally as I've just handed it over to the autospark (again) but I'm told the battery is fine.
ballsack
15
Did you get anywhere with this issue?
Well.... Car is back after having the cam sensor replaced now . He also did find a connection to the alternator that was dodgy .
I'll let you know in a few days if the starting issue goes away
