Just had a bit of a scare with my Toledo. Start sequence all fine, open drivers door and fuel pump runs, turn key, everything goes live, fuel pump goes again and relevant lights go out, turn key to start the engine and nothing.......... apart from some more buzzing (im assuming that its the fuel pump).
You can call me a muppet as I had no breakdown cover (soon to be rectified!!!) so I was a bit lost at sea. I have no tools in the car so couldnt just disconnect the battery in the hope that something would reset but there is however a load of cables coming towards the engine from below the battery with a plug above them. Disconnected the plug and something clicked, plugged it back in, turned the key and the engine reluctantly fired.
What could it be that caused it?!?!?!? Oh and car is seemingly now fine (same as before).
