IHI downpipe/exhaust system
Cupra 200bhp
Hey just need a little info on DP's and exhaust for IHI'd ibiza's!
What downpipe is everyone running who has IHI?
Also what size of downpipe?
Final question, what size of exhaust and has anyone taken front silencer out?
Any help would be appreciated as i think my IHI ibiza has had the wrong exhaust fitted by a company up here in scotland.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
IHI DP is specific IHI and from Jabba, made by Blueflame
It is 2.5" diameter and space is VERY tight between turbo outlet and rear engine mount.
It would benefit from being 3" but space is a real premium.
No less than 2.5" exhaust probably larger if possible.
Mine ran with front silencer out, decat for a long time before going to full 3" DP and system. (one off 3" DP so not available)
Cupra 200bhp
Im sure my downpipe has a small hairline crack as there is a small blow from the that area? Its a 2.5" system thats on it the now but considering selling this and going for 3"? Would i benefit from this? I had 3" downpipe and system on my k03s ibiza and i like that system better from A & M?
What sort of cost is it for IHI downpipe? Do blueflame stock them? Any other people make them?
dan-ish
Audi Techie
Jan 26, 2005
205
darwen
I think only Jabba sell them mate give them a call 01733211779.
It's very tight for a 3" pipe so would be extremly expensive to have one custom made.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
If split it could be warranty back on BF, which they should do. (repair)
removing it is a pig however.
3" system on the 2.5" DP is loud for no gain I imagine.
3" full system on mine from 3" DP to 3" full system seems to have added nothing surprisingly... but then again its not running right either so maybe I will reserve judgement until its as it should be
dan-ish
Audi Techie
Jan 26, 2005
205
darwen
You havin running problems?
Wilko
Badge snob
Similar feeling here. Car running great, apart from smoking like a diesel, but oil leak causing burning smell.Bugger!
Oh well, oil leak should be fixed tomorrow, and new mapping too. I bloomin hope this is the end of it, and I can have a few months fun
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Do 3bar map sensors read the same voltage range? - ie what was 2bar creates the same voltage as 3bar?
Removing N249 is a doddle, and well worth it - who wants the ECU dumping mid throttle!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Still a 0-5v sensor SFAIK
forget vag-com logging afterwards tho.... all to cok
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
that's what I was thinking - just need to scale the boost as well rather than plug & play (and read the right number)
Glenn
513
The sensors use 0-5 V as it's the maximum range of the Analogue-Digital convertors on board the ECU processor. There is a register which allows you to set different upper & lower limits within that 0-5V for better resolution when converting a narrow range signal. This is based on an older Motronic system (M2.9) but I expect it's the same for later setups. If you know the processor model, you might be able to find the datasheet & confirm.
caney
600
jesus christ you must love that car wilko! how much trouble have you had with it? hope you get it sorted:)
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Its all relative, but as for "all" the related maps being adjusted to allow for the different scaling.... :think: remains to be seen.
Not advised by some tuners to do this mod.
Std table will saturate at 1.55bar boost... and mine runs 1.6bar Sit at top (and beyond slightly) of table ot rerange lower down and regain some resolution... Debatable, dependant on tuning tools probably, and personal ethos on whats best to tune a car like.
I can definately believe reranging a MAP sensor to 3bar will influence many internal maps in the ME7, and how many of these maps are used for normal tuning (hence being adjustable) is a question I dont have an answer for.
30K relatively trouble free motoring on the std MAP sensor running 1.6bar on VF34 would say to me it can work fine to that level on std MAP sensor.
Cupra 200bhp
Has anyone got a number for BF so i can call them see what they say??
