Illegal Modifications - What is the Law?
Pimped up vario
Cordy Cruizer
Nov 20, 2009
1,291
Belfast N Ireland
It has to be said though that a sensible suspension set up is paramount to safety. I had a mk1 jetta 1.5gl at one stage in my life. It was a long time ago and to say it had a recent mot would be a stretch. It would not be a stretch though to say that it had a valid mot not long after a bought it. At the time of purchase it already had a set of lowering springs in it, make unknown. I took a trip along a road at speed which has a hump near the end of it 50 yards or so from a t junction which terminates at a angle instead of perpendicular. Anyway, I know this road and still managed to get air born and ended up in the middle of the road, not good. I quickly fitted a set of boge turbo gas uprated and shorted stroke dampers with matching boge springs and powerflex bushes on the front arms. I did put pagid fast road pads and vented discs o but that is somewhat irrelevant as the second time down the road I did not get air born at the same speed at the same hump. The car came straight back down to planet earth.
Your suspension setup sounds very bouncy to me and not very forgiving at high speeds or if were not meant to be speeding then along bumpy back roads.
Dlp1984
226
Sidcup
I had a celica that was almost identical to the story above. I was driving down the m20, outside lane doing around 80mph, there is a section of the motorway near Maidstone that's been built in sections and as a result the joins in the road bump up slightly. Now I'd been down this part of road many a time in cars prior to the celica, but this celica had them cheap coil over kits that go over the stock strut and you can lower the car as much as you please, the car was pretty slammed and had no real bounce to it, I hit this bump in the road and it chucked me up and I smacked my head on the roof of the car, I was luck it didn't knock me out as at 80mph on the outside lane I probably wouldn't have killed myself, possibly my passenger and potentially anyone near me at the time, so I can see why a rock hard suspension could be dangerous
