Immobiliser problem following attempted theft
fatty86
What a knob-head! Lost my keys on holidays and tried to hotwire my Seat Ibiza to get home. Big mistake!!! Loads of volunteer car wreckers offered advice and resulted in fuel pump breaking beyond repair, Ignition barrel smashed and now unable to know where to start to repair.
Can anyone help? The immobiliser prevents fuel pump working.:cry::cry:
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
You'll need your skc and a new set of locks. Or probably easier to find someone scrapping the same car as yours. Take the locks, ecu, immobiliser box and keys.
fatty86
Or you could bypass the immobiliser by adding a manual switch and wiring for the fuel pump.
thanks m8 this sounds like my best bet as the budget is very small at the moment.
dont suppose you or any body could tell me if you can do this on a fly by electronic throtlle version. ive been told it cant be done.
also as ive alredy destroyed the origional fuel pump trying all sorts will i be able to just replace it with a second hand pump from another car eg vw polo, golf,caddy:think: longs its a 1.9 tdi and still by pass the imobilizer
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Ouch, I thought it was a petrol. Bypassing the immobiliser isn't so simple on the diesel. It will be cheaper for you to sort it the proper way. Or speak to CCC tuning and ask them if they can turn your immobiliser off in your ecu. How do you know the fuel pump is broken?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
is the reader coil broken ?
the plastic cap that fit's over the end of the ignition
fatty86
hi m8 no the reader cap isnt broken that bit is still whole lol not to much use without the key thow is it? cheers:lol:
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Number 1, get a dealer to order you a key from your vin number
Number 2, Get a dealer or decent autolocksmith to reprogram your immo with new keys.
fatty86
yeh i figgerd this would be the case m8 cost me an arm and a leg lol. the pump is broken because i and a few other destroyers decided to start taking it apart to see wot was causing the cut off to the injectors then all the bits came falling out from inside the pump springs washers spacers:-o cheers
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Ouch, your fooked. New injector pump time. And I guess you don't know how to retime the cambelt. Then all the other stuff like new ignition barrel key and immobiliser building.
Injector Pump = £100 if your lucky
Fitting of Pump = £200ish including new cambelt
New Ignition Barrel, Sceptically euro car parts sell one with a key for £6.70
New key from dealers via VIN number for doors £20 each
Immobiliser Coding from dealer £70
Where are you from?
fatty86
nice one m8 that is very helpfull now i got an idea of how much its going to cost me.
proper job cant fault you.:coolthumb
im from the valleys in south wales m8
